Guess' ????
Guess' ????
Dropped exhaust at collectors
81* and 78% humidity...with weather coming in (hope it passes)
Now...what you think she'll do with no other changes exhaust was ???100#ish and a 2.5" dual system w/ H-pipe.
Track was ****. I watched them spray and drag, but I guess the humidity won out ?
Spun bad first pass on launch and at the 1-2 shift....just cruised out the back end.
Second pass, feels better (hooked), 11.61 @ 116.15 AFR on top end 12.6-8
Track guy tells me slow it down ??? said I went 11.0 on time board ...I get slip 11.61
Third pass, spun bad again, peddle it, hit second and pops a few times at top of second, hit third and it starts popping...let out and cruise out the back end. Head for truck.
I know this car can go faster, but seems it's stuck here in the low to mid 11's... WTF ?
I watched 1 wreck, and 3 oil downs...loaded up and went home. Storms coming and didn't want to get caught in it. Got home, car and trailer in garage....about an hour later it poured.
OH, and the exhaust is going back on
OH, and Dragtimes showed a 2414' DA so I punched in my numbers and...
Correct your ET and MPH using the DA
11.28 @ 119.622 MPH
11.28 @ 119.622 MPH
OK, looking at Best ET/MPH back in Oct'13
I made my 1st pass at 32* and went 11.80 @ 113.32...Now, not taking into account the DA This time out with the same settings I went .2 and 3mph faster dropping the exhaust. (I guess .1 could account for the weight ?)
34* made my best MPH at 117.71
36* made best 60' by .1, .01 better 660', and .003 better ET losing 1mph in the 1/4
I made no changes at the track since I only got 1 clean pass. I'm going back to 34*
This thing is still down on power SOMEWHERE
With respect to your timing, sounds like you need the 36* in it below tq peak and 32* beyond that. My similar engine made pk tq @ 5400 fyi.
The popping at the top of each gear sounds like a fuel supply problem. - check for crud in the needle and searts, and verify float levels are right
Old School Heavy
Next, here is what I would do:
- I would do a compression check on all cylinders just to rule out issue
- Replace all the plugs with fresh TR6s
- Check all the wires with an ohm meter
- Double check jetting to make sure it is factory jetting for that carburetor
- Make sure the powervalve arrangement is factory
- Double check the bowl's float levels
- Double check full throttle operation
- Double check all grounds and power supply to the MSD
Next trip to the track:
- Make 2 baseline runs. Make sure they are clean passes.
- Make sure the 2 passes have similar performance. If they do not, make another. You are looking for repeatable consistency to assure you have an accurate baseline.
- Next, jet up 2 jet sizes all the way around and make a pass. Must be a good clean pass. If is speeds up, jet up 2 more sizes. Repeat.
- If it slows down when you jet up, then jet down all 4 corners 2 jet sizes from factory. If it speeds up, repeat.
Once that is done, you will be confident about the timing and jetting and you can move on to other concerns like cam timing. Most important for me in these scenarios is to just stay calm, put my expectation away and do the work. I find it more enjoyable that way and it usually makes me more effective.
Only was popping on last pass...I think it was due to low fuel level in the cell (thought I had half a tank I guess due to being on the trailer and not level ?)
Looks like I'll be busy for a little bit
I just wish the combo I copied could give me so more info...would make this easier for sure.
I don't get to the track as often as I'd like, so tuning this thing is going to be a while.
Thanks for all the help....getting discouraged
My 383 sbc I built in 2003 first time at the track was running 12.30s, I adjusted the timing from 32 to 38 degrees and the next pass it went 11.70.
I like to isolate aspects of the car and tune one thing at a time. I see too many people change 10 things after a pass and then go faster/slower and don't what change caused it.
You should be able to get some more out of your combo.
Good Luck!
Good Luck!
