First time LS1 project user needing combo advice
All, I am currently building a 79' Pro Touring Malibu. I just recently bought a stock 6.0 out of a 2000' 2500 pickup. The motor has 138,000 miles. I want to go carberated with this motor and am looking for a very hard hitting combonation. My plan is to re-ring and bearing the bottom end while installing a new set of heads (complete), cam and lifters. I have a nice 750 APD carb and want to run an aftermarket intake. I would like to hear your suggestions on what I should go with. I'm looking for a cam that will make power but also sounds very radical. By the way, I have a T56 6 speed for a transmission that I will be running. Let me know if you need any other specs. Thanks in advance for the help...
In-Zane Moderator
Install some ARP bolts in the rods, LS3 heads, custom cam from Martin at tick performance, super Vic intake and some 4.30 gears, and get used to the pain in the cheeks from the grin you will always have on your face while driving. Sounds like you have the rest in the ball park man.
