What fuel
What fuel
I just got my 6 liter swap done and took it for the first drive. Its a stock L96 , 9.6-1 comp, with a 237/245 @ .050 cam, morel lifters, Holley dual plane, 1 3/4 headers and my old pro-systems 780. I have 91 octane in the tank now but am thinking I could even run mid grade. I have the timing set at 29 total right now.
My first impressions of this engine are, where is the torque. lol I had a 600-650 hp 496 bbc in the car before.
In-Zane Moderator
What converter and gearing? Those things can make torque feel lower if it isn't flashing I to the power band and fighting tall gears.
I would run mid grade(89) if you can. If it diesels down you will know when you cut it off.
Bumping the timing is going to help as well. Try 34 and creep it up a touch from there if you can. That thing may like 36 and that's where the torque will start coming in higher with the HP.
3.73's with a 5 speed tremec
I didn't expect it to have the torque the big block did. It is just a lot different going from that to a small cube engine. I will play with the timing too.
7500 rpm peak?! Out of everyone in this forum that needs to advance their camshaft, this is taking it to a whole other level of retardation!
109 with 105 icl. Pistons are not cut and are close on the intakes
Guys I have only had the car out once without playing with the carb and timing yet. I never expected it to have the torque of the big block. It actually ran pretty dam good for the first time. I went 29 degrees on the timing to be conservative. I am old school chevy so this engine is a bit foreign to me as far as tuning goes.
One thing I have to try and correct or improve is the valve train noise. I read about it while putting this engine together but figured it was the same as the bbc guys complain about their Morels. I had Morels in my 496 and they made a bit of noise, never bothered me, but this thing is quite loud.
65 Beaumont , about 3500lbs
Old School Heavy
Those specs in the calculator show:
IVO is 13.5 ° BTDC ( - indicates ATDC)
IVC is 43.5 ° ABDC
EVO is 55.5 ° ATDC ( - indicates BTDC)
EVC is 9.5 ° BBDC
Overlap is 23 °
13.5 degree IVO on square port heads without fly-cutting? I am shocked to hear that cleared.
Great looking Beau! We don't see those here in the states.
IVC is 43.5 ° ABDC
EVC is 9.5 ° BBDC
Overlap is 23 °
