I am at a loss my MSD works on other cars but not mine
I can not figure it out my car is wired correctly I've triple checked everything but I can not get spark I have tested my harness and box on a friends car started first time I've bought new sensors new plugs leads coil packs tried to bypass my cars wiring and run off a separate battery still nothing I have a LHS hi tourque starter that's the only thing I can think off could be the problem I have no revs shown on tachometer but all the correct voltage at all the right points and times a
I'm stumped any help would be great cause I am out of ideas
If the box works on your friends car, then does his box work on yours? Are you swapping out just the box or the whole harness too?
Not sure if this is it but back in the early days it wasn't uncommon to find a box that was incompatible with specific cranks, usually aftermarket cranks. With no crank signal the thing isn't going to fire.
Give MSD a call and have them see if they can come up with a meaningful test. They might end up having you send the box in. Sometimes they can fix it with a reflash.
thanks for all the replys
yep put all new sensors in and tried the ones off a mates car only thing I can think off if even possible is im using a hi torque LHS starter motor is it possible it could be dropping the voltage when im trying to start it? I have a relay on it as well the motor is standard with a cam and was running when pulled out of another car???
I'm to scared to try my mates box in my car in case I damage it
