Carbed 6.0 HP numbers - check this article out!
http://www.popularhotrodding.com/tec...e/viewall.html
Now tell me, am I missing something here or does this thing seem at least 30hp down from where it should be?
The big thing that sticks out to me isn't as much the power it made, but rather WHERE it made it. Were all swinging our 6.0s over 7000. Bret made peak power at 6500 with this one. That's pretty impressive IMHO. And the torque numbers are pretty wicked as well. Besides being a solid roller, talk about some ODD cam specs compared to what were used to? Its interesting. Eric L
Reading up on the engine masters challenge, at least back in 2009, apparently scoring was based on average torque and HP numbers from 3000 - 7000 rpm.
Makes sense that they could have designed the cam to bring in strong torque through the entire rev range, and peak HP early and hold out right through to max revs.
3pedals, is this the same Bret Bowers that designed your cam that made some astronomical HP numbers?
Yeah it'd be interesting to see the correction factor and atmospheric conditions, of all of the above dyno sessions. I don't think a lot of these motors are really making as much power as most think they are. Making near 600hp with under 400 cubic inch isn't an easy feat for a street engine.
so many different ideas and formulas for hp based on lbs/trap speed. I never did see the correction factor on my N/A motor, but heres it's performance:
131mph @ 3505lbs stock 6.0 displacement
Wallace racing calculator says 631 flywheel based on mph/lbs
Yeah interesting. It does seem unrealistic that these simple combo's could make over 600hp. But pro systems calculator says you were making 622hp, and Moroso slide says basically 605hp.
From now on, I am sticking with the Moroso which also seems more accurate with other cars performance I am familiar with.
Although I am wondering if there would be a way to dyno test an engine with the torque converter in place.
Torque converters multiply torque, and HP is merely a calculation of torque at a given RPM. Are torque converters actually increasing flywheel output even at the very top end of the rev range? Which theoretically this could explain why we see engine combo's that by rights should make no more than 550-560hp, are being calculated as making 580-600hp with the quarter mile efforts achieved?
I don't have a definitive answer anyway.
Oh and yeah, I believe you were probably running a stick shift 3pedals.. just theorising on the more common auto/stall situation.
Old School Heavy
Out of all the calculators, I like this one that Doug found:
http://www.wallaceracing.com/hpcalculatorquarter.php
Based on my experience and actual dyno results, I think it is accurate.
