lq4 with prc as cast 225
I am getting ready to buy a set of heads and was wonding what kind of power these heads would make with a super Victor and 950 carb? Haven't decided on a camshaft yet.
Gonna put this in a 81 Malibu that weighs 3300lbs with 4.10 gear and 4000 converter. Any 1/8 th mile track predictions? I wanting to run in the 6's na on pump gas
Old School Heavy
Welcome to the carb section jonz. While I have never tried those heads personally, if PRC has their name on them, I would run them.
As for making 6s in the eighth at 3300 pounds with a good set of heads, EASY. My car is 3700 pounds and I have PRC CNC ported factory 799 castings, smallish 226/234 cam, Vic Jr., 4000 stall. My car goes 7.0s in the 1/8 on the motor.
Ya I have been looking at the Ls6 2.5 also which sounds like what u got. And then ive thought about ls3 stuff but I think that big of runner size will kill all the torque
Old School Heavy
I actually have the Stage 1 CNC LS6 heads. As for the square port stuff, you can get it done with those no problem too. It just depends on what you are doing. If you are using a stock junkyard short block, there are some advantages to running the cathedral port stuff. If you are going to build the bottom end with forged pistons, I would say it is a coin toss.
