efi pump ?
efi pump ?
Im going carbed on a 99 z28 and was wondering how much hp the stock in tank pump will support and also will it work fine with a heads cam combo? also what size return line would you guys recommend off the Mallory 4309 regulator? and is there anything special that needs to be done to use the stock fuel feed line on the 4th gens? thanks
thanks and I ended up getting 1/2 for the return just need to figure out how im going to plumb that back into the tank
