fuel pump??
fuel pump??
Alright so ive gone carbed on my 99 z28 i have the 6ls box and mallory regulator all the wiring not needed for the old fuel injection has been removed im still using the stock in tank pump with a 1/2in return line off the regulator question is when i turn the key on the pump primes but after i belive it stays off. Fuel pressure goes from 6 1/2 down to zero when the cars running in a matter of 20secs is there a way to tap the fuel pump relay into the ignition relay to keep the pump on when running or what would be the best way to do so?
In-Zane Moderator
I have done that many times, if you pull the rear carpet up that is behind the rear seats, you will see the wires that go to the fuel pump and sender. It should also have a relay under the hood that has a wire that can be jumped to a constant 12 bolt key ignition position or use a switch if you like. Or a combination of the two.
I just wish I could tell you which relay and wires to use, I just do not remember the color.
thanks for the responses guys we got it figured out and got the car running yesterday one more question I have I had a autometer 5in tach in the car before and it worked fine now I have it wired to the 6ls box and its way off driving about 45mph said I was at 5k rpms wich shoulda been more like 3k rpms and when I got on it for a sec it shot to 10k rpms lol do I need to cut or reattach one of the wires on the back of the tach since im running threw the 6ls box instead of the stock ecu? ill throw a few pictures of the car on here when I get a chance to
