5.3 cam advice with nitrous !!!!
Hi im building a c/k 10 truck with a 5.3 engine that i want to get the most out of it, i will be using 317 heads with yellow spring, it has a 350 trans with a 3500rpm stall and 4.10 gears, i need your advice on a good 1 bolt cam for this build, i want to use a 125hp shoot of nitrous ocassionally on the track, i want to buy the cam so i can go to the track next week, any advice woul be great!!
Old School Heavy
This is the one i would pick, but you will need some good valve springs and hardened pushrods.
http://www.tickperformance.com/tick-...1-ls6-engines/
