Neanderthal Carb Guy BS Thread
#242
i too am working in an oversized 2 car garage. so far it is good enough, and i think with some well thought out storage solutions i'll be fine for a long time. my yard is basically a hill from the street upwards to the rear of the lot and no way to put a larger shop in without having an engineer come lay out the lot in such a way that i wouldn't have drainage issues. personally i'm thinking of a building off site, but that's way off in the future, lol. a 3 car garage would be fine, but something like a 40x60 would be ****.
#244
I would be fine if it was just the s10. But i have the s10 and a rzr in there along with a 42" box, shop fan, 80 gal compressor, workbench, refridgerator blah blah i need more room lol
I want tk get myself a press and welder, but im not sure where i could keep them
#246
It definately gets tight quickly. The garage I built my 73 in when I lived in AZ was a very small 2 car (18ft wide by 19ft deep). I had my TA and the Camaro parked in there. I would pull the TA out and move the Camaro to the center each time I worked until I finally got fed up and put the TA in storage. The other part that sucked was that we had no basement (AZ) so all the Christmas decorations, etc were stored along the walls on shelving. It was TIGHT! I'd love to have the shops that my buddies have, but this 3-car is a HUGE improvement over what I'm used to for sure.
#247
Going from carbed 355 to carbed LM7
Thought I would introduce myself.
Built a 355 vortec sbc this past winter and just got my first LS this weekend. So far it looks like it will go in for the 2016 racing season.
Personal best so far: 12.03 @110; 1.58 60'
Build details on the carbed 355:
355 Vortec-headed SBC
Holley 650 DP
Airgap intake
Elgin; 216/228 @ .050, 453/480, 112lc
Headman Longtubes
Walter Racecraft Y-pipe w/ Dynomax race bullets
TH400 w/ RMVB
Hurst Quarterstick
Stock 3rd gen 10 bolt – 3.73 Lincoln locker
7 point Comp Engineering rollbar
Front Comp Eng. 90/10
Rear Comp Eng. 50/50
LCA & relocation brackets
Subframe connectors
M/T Drag Radials on Weld Draglites
Holley 650 DP
Airgap intake
Headman Longtubes
TH400 w/ RMVB
Hurst Quarterstick
Subframe connectors
#251
You will love not having a distributor to mess with. However you are a long ways from optimizing what you have. That engine has 906 heads on it? They are usually the ones with the hardened seat (they flow a little less on the exhaust side). Look through the site here at the LT1 cams for sale and get rid of that baby elgin cam. At .480 lift presently I would think you already have the guide bosses milled down and PC seals. Hopefully even screw in studs. If nothing else pin them. A 274 xtreme or bigger would pick what you have currently up. Remember a lot of the LT1 cams list 1.6 rocker lifts so you need to reduce it to 1.5 numbers if you have 1.5's.
What rpm stall do you have?
#253
The RPM capabilities and power up top will be an eye opener when he finally switches over for sure
#255
this engine has some "issues" that i won't go into as it's quite the long story. nothing wrong reliability wise, but would need a full valvetrain revamp, and that will easily cost a good chunk's worth of the ls swap...so...swap swap swap!
#259
You know the best part? I had driven the car up there from Woodbridge VA. In my panic I started walking through the staging lanes asking other 4th gen owners if they knew where I could find a drive shaft in a hurry. Turns out, one guy who only lived 10 minutes away had a spare laying at his house. AND.....unbelievably....it already had a 1350 cross joint installed in it to work with my Moser 12-bolt! To top it all......this guy who I had just met let me borrow the drive shaft to get myself home. Thank God for hot rodders! That dude saved me one hell of a towing fee. I ultimately sent him a check and bought the drive shaft from him.
