Rocker arms which ones to go for
Im looking in to getting sum new roller rockers which ones to go for Yella Terra or Scorpion GM stock rockers are a rip off in AUS so that's why im looking in to aftermarket ones
Not going solid im 50 off the 650 lift mark it just GM rockers are going for $35 for intake and $80 for the exhaust that each aftermarket are $780 for a set that Scorpion or Yella terra so like to know which ones are better I hear all good thing about and I had yerra terra on my 383 sbc on a solid cam had no problems with them
Old School Heavy
If I had stock rockers I would use them and if I was going to ship sum from your side of home with a set off comp trunion kit it would cost me more so that why im looking in to going with aftermarket I have seen on sum sites if you go with 1.85 there have made 13 rwhp cheap way to go to
Old School Heavy
High ratio rockers can be a great choice for some applications. However, and you may already know this, roller rockers are heavier and require a different valve spring than is optimum with stock rockers. You will need more nose pressure to handle that additional weight. Also, higher ratio rockers work better with cam that was designed for them.
Are you needing a LS1....LS3.... Or LS7 Rocker set-up? That stuff is way cheaper here and USPS priority shipping should not be to crazy since it all fits in a flat rate box easily.
Go the stock rockers but do the trunion upgrade. Check gumtreen ebay or facebook groups, shoukd be able to get set cheap.
I run that on mild L98 spinning to 7500 rpm, running 10.0 in light vk
