Carb Size for 427-433cuin LSX Nitrous Motor
Just looking for some input on carb size for the following motor.
427-433cuin LSX 4" stroke 4.125-4.155 bore
11.5:1 Comp
cam 250-260 duration .630 lift
LS3 style heads 250cc to 270cc, flow 360ish at .700
LS3 super vic.
Direct port nitrous kit - 250 to 400 shot
3200lb car with 1.80 glide and brake, 3.73 gears
4150 carb or 4500?
something in the 1000cfm to 1150cfm range?
Any input appreciated.
11.5:1 Comp
LS3 super vic.
4150 carb or 4500?
I believe I would agree with the other guys on this one. My 408 ended up with a 1000 cfm 4150, but with your bigger engine should need more.
I would keep in mind if you're planning on any class racing to see if they're any weight breaks for 4150. Mine is 75# so I stayed 4150
Quick Fuel Tech is glad to help if you call them.
If you can get Dale Cubic on the phone, he's one of the best, but pricey
If you were restricted to 4150 flange I had the perfect QFT carb for that setup. I am about to put it up for sale I think.
Its a Q series 4150, custom built for my 383ci race motor with a n2o plate kit.
It is a 950 main body with ann boosters. It flows 1125cfm.
It was on a super victor pulling air through arf 205's at the command of a 248/258 solid roller at .650" lift. With 383 ci and this top end, it made around 600 fwhp.
