cam gurus thoughts on my new cam
Specs are .632/.596, 251/266 @ .050
108.0 intake center line
112.0 lobe seperation.
My combo is 370 with as cast tfs 220 heads, Victor jr. Qft 850. Sledgehammer plate kit.
Car ran 5.70's with a polluter cam. The polluter specs are .610/.612, 242/244@ .050. 112.0 ICL. 112 lobe seperation.How much do you guys think this cam will pick up if any. I am hoping to gain 2 or 3 tenths on the same size shot.Thanks in advance.
Hard to say what it should pick up, due to many different variables, but that's quite a but more aggressive. If the rest of your combo can match it then it should do well obviously
I'd be checking piston to valve clearance very carefully. And dogsballs like a couple of things cam related, I have noticed your understanding is the opposite to how things actually work.
Lol, thanks mr always right. I'll sleep better at night knowing you are the all mighty mr engine know it all. Thanks you are doing the world a service
Looking at the valve events this is no doubt ideal for the given nitrous application. Getting the crap out the exhaust is exactly what is needed, and overlap is of little importance.
This cam has been spec'd by Brian Tooley, enough said.
