Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
E85 ring gap
Old 12-22-2014, 02:55 PM
snowman47's Avatar
Default E85 ring gap
Could you run a tighter ring gap using e85 compared to other pump gas? This is for a n/a stock bottom ly6..mainly street use/abuse.
Old 12-22-2014, 04:07 PM
WE TODD DID's Avatar
Could you? Yes. Should you? NO.
Old 12-22-2014, 04:30 PM
Doug G's Avatar
A lot of these motors started life at GM were/are flex fuel rated...nothing special for the ring gaps that I'm aware of.
Old 12-22-2014, 04:54 PM
snowman47's Avatar
I didn't think so since I couldn't find anything on the interweb saying otherwise. I was just curious since e85 burns cooler that maybe you wouldn't need a standard gap size. The reason I ask is because I found out the top ring is gapped to .015 which seems too tight..
Quick Reply: E85 ring gap
