Cam suggestions??
Anyone can grind it, but I use and recommend Cam Motion. If you want that cam from them, just call Cam Motion and ask for Danny. This is the grind number for that cam:
XA228/370-XA242/355-11+3
Also, I just noticed that the GMPP heads you are planning have 66cc chambers. Before you order your cam, make sure you ask GMPP if the heads are milled and what the "Valve drop" measurement is on the heads. This will affect your piston to valve clearance. Let us know what they say.
__________________
The Switch Is On To Cam Motion!
40 years of Championship Winning Experience • Superior 8620 Steel Camshaft Cores • Quiet, Smooth & Powerful Lobe Design • Virtually Unlimited Lift and Duration Combinations • Finish Polished For Quiet Operation • Cam Doctor Printout With All Cams
The Industry's Best Customer Service
www.CamMotion.com • ☎ 225-926-6110 • Like Us On Facebook!
Some more intake duration would be nice, but if you are limited by valve clearance with stock pistons, that cam is a good choice. Give us a call when you are ready. We will do our best to make you a customer for life.
__________________
