5.0 stang being a nuisance
I'm pretty low key with my camaro. Ill air it out every once in a while. But I try to be courteous in the town. My car is quite the noise maker and attention grabber, both good and bad, so i mind my manners for the most part.
To the question.... There is this new 5.0 lurking around doing drive byes ringing the pipes, ha i suppose to get my attention. Havnt dynoed, but i'm trapping 124 in the 1/4 @3600 lbs, I would guess i'm low 500s hp n/a. stang sounds stock, or moderatly modified. How are those cars running compared to ours. (or my set up)?
In-Zane Moderator
Stock they can run 12s with the right factory options and driver on radials. With a tuner, exhaust and tires, they can run very deep into the elevens and they are some times lighter than your car from what I have seen. Your car should be able to make more traction on the street of you have the suspension set up right. And there for make it hard for him to have a chance. This is assuming a dig race not a rolling start.
