Lm7 in 66 nova. Carb vs efi
Should I stick with the fuel injection or go with a carb and msd box?? what are the advantages or disadvantages of both?? Car will be 90% street car and see little track will be 5.3 mills 799 heads a nice cam and probably a 100 shot
In-Zane Moderator
I have a ton of info in here, covering carb application for frequent questions. Think there is some of this as well:
https://ls1tech.com/forums/carburete...need-know.html
The carb is simple. And can pull as good of mileage as EFI or right behind it. All in the tune and setup. And power? Carb will always make more power over conventional EFI.
Just depends on how you want to do things and your capabilities or the people helping.
My toys are all older and keep carb setups. Daily driven and all, zero issue. It's when they sit over and over that the carb can gum up a bit from the ethanol on today's fuel.
And when you whoop someone's *** with a carbed engine, you get to laugh and tell them a junky old out dated carb setup just drug that ***.
Old School Heavy
If you are a guy who likes to work on all of his own stuff and knows carburetors, then I would say stay carbureted. I did not want to learn to program and ECU nor did I want to chase around a pimple face kid to do it for me at $500 a pop. LOL I tend to make a lot of changes to my car and tinker. I don't have to worry about paying somebody to re-tune the car every time I decide to change something.
Are there any alternatives to controlling a 4l60e without that $600 ez kit?? Should I ditch the trans for a 700r I defiantly want overdrive and I don't want to hack up my tunnel to do it. Maybe staying fuel injected is a better option for me all though the fuel pump and tanks will probably cost a fortune too
In-Zane Moderator
The 200R4 is a smaller trans that is able to handle a ton of power and not require hacking up anything I think
I know there is a 200$ manual trans controller box I use on my 4L80 transmissions so call jakes transmissions and see if they can do the same for a 60. I don't see why it wouldn't be possible.
