Hotrod Carbed Intake Dyno Test
Check this out. Hotrod tests 20 different intakes on a hot 6 liter LS incuding the Performer RPM, Vic Jr., Holley single plane and some Dual Quad setups.
http://www.hotrod.com/features/1507-...ifolds-tested/
Also worth noting that the LS1 Vic Jr has a small CSA in the runners, compared with the LS3 Vic Jr intake.
Interesting to see the torque made with the Fast 102 which would be my pick for an EFI setup.
A little more on the motor would have been nice also....Sounds like about 10:1-11:1 comp.
A better carb cam (as said above).
Still not too bad...all were in the 550 +/- range (on a quick look-see).
Thanks for the link Tiggs.
Here I sit with the Holley two four dual plane intake and twin 660 center squirters on my Katech LS3. Thought it would be nice for the Nostalgia drags. Not allowed EFI. Maybe a trip to my flow bench to see some #'s.
I was thinking 6,000rpm launch with T56 and 325x60 MT ET Streets in 2,600# car would be fun.
I guess a day on the dyno and a Vic JR to compare will be in the works as well.
Aleck
Aleck
In curious on the timing too. It seems the carb setups always run more timing. Also why did they shut down the pull on that symbol performance intake? It never peaked and was looking to keep climbing hard
I'm just wondering if maybe with more tuning the carbs could have surpased some of the fi intakes. I have a Fast 102 and 102NM tbody and saw it made almost 50 hp more then the carb intakes. Didnt seem right to me. Maybe the average tuner like me wouldnt have that last hp squeezed from FI like they did.
