Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
carb jetting
Old 02-28-2016, 06:22 PM
kennymox510's Avatar
Default carb jetting
What size jets would you guys start of with?
Motor is a 5.3 with holley single plane, 228/230 .600/.600 110 cam, 1 3/4 longtubes with single chamber flows.
Carb is a proform 750 race series carb that currently has 74/84 jets (factory size) in it. 6.5 powervalve
It runs pretty rich
Old 02-28-2016, 06:28 PM
Default more info.
Idle bleed is 70
Hi speed bleed is 33
Pri/sec nozzles are 31
Old 03-02-2016, 02:47 PM
Old School Heavy
speedtigger's Avatar
When you say it "runs rich" do you mean at idle and cruise or at WOT?
Old 03-03-2016, 11:03 PM
Pretty much all the way through from idle to wot less noticable at cruising speed but at idle i smell it pretty bad and if i do even a 60' wot pull, as soon as i let off the gas it smells like i dumped
A gallon of gas inside the car
Old 03-05-2016, 07:54 PM
LQ4BU's Avatar
If tune my carb using the A/F meter it always smells rich as well. But if I tune it by highest rpm and vacuum it seems to not smell as rich. I got my best times with 74-84 so far.
Quick Reply: carb jetting
