First time at track with lq4 build
Hello I am new to the forum I just recently built a 03 lq4 stock bottom end with arp rod bolts for my 85 Monte Carlo as I bracket race the car it have 862 ported head a victor Jr carb intake and a 750 double pumper with a ho main body my first pass was 12.11@111 with timing at 28 degrees in at 2000rpm I'm thinking the car should have gone faster I would like you guys input
cam specs
compression
who ported the heads
transmission
converter
rear end
weight of the car
tires
suspension
DA of the track
ambient temperature and humidity that day
Cam is a srd cam spec if I remember is like 610/598 232/240@50 with 108 heads where ported by a guy I've been use for a couple of years in nj head flow 310@650 car weights 3550 with me I have 4500 edge convertor 4.11 gears compression I guess should be around 10 with 862 5.3 heads car has tubular upper and lower control arm anti roll bar the car was getting 1.57 to 1.60 60ft wit my 383 going 11.30@120
In-Zane Moderator
This sounds like I'm getting old, but I think my LQ4 with stock milled heads and a Trex cam went 11.18 at 121 in my 89 RS. That was a 1.55 60 foot, car was 3450 with me in the seat. Seems you should get more out of it. Wonder if you have a converter issue or something else?
This is on street radials too and a terrible 1.8-60' time. Bump up the timing at the track till u stop gaining mph. Make sure you are getting WOT at carb. Sounds stupid but I found out my gas pedal was bent. Went .20 faster after I fixed it
Quick update guy thank you for your input now I have a good starting point went to the track again today I bump the timing up to 34 degrees and gap the plugs to .45 and the car picked up went 11.52 first time shot shifting at 6000 rpm
