Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
New MSD ignition controller. Yes, NEW
Old 08-30-2016, 03:37 PM
  #41
Petey-Pop-383's Avatar
how much timing are you pulling at the hit to make it hook on top of the timing pulled for the jet your using?
Old 08-30-2016, 05:22 PM
  #42
jgillen91's Avatar
On .082 jet (240hp) Base timing in the rpm vs timing graph is 35 degrees. I pull 10 degrees for this shot in the step retard when nitrous is activated. The I pull another 15 degrees on trans take release and slowly ramp it back in in the first 2 seconds to a total of 25 degrees That graph was a 1.25 60' 5.48 @ 130mph that is pretty much as dumbed down as I can get it on a hot slippery track and 26x8.5 tires
Old 06-19-2017, 12:06 AM
  #43
Boxchevyken's Avatar
Originally Posted by jgillen91
Got the 6014 running . Cam/crank jumper harnesses are mis labeled. Pretty easy to figure out. Other than that all good!
I installed my 6014 box and harness but not getting any spark. What was mislabeled? Or what pins have to be switched
Old 06-19-2017, 05:17 AM
  #44
TTur1996's Avatar
Originally Posted by baronsmith98
Man that's nice. Can you hook up an external wideband to log?
I use a fast Wideband unit. Don't think you can hook a o2 sensor into any msd software
We run the Fast wide band as well. It has its own data logging. It logs AFR and rpm if you get the add-on rpm module. It can also be hooked to an external data logger to tie everything together.
Old 06-19-2017, 05:42 AM
  #45
TTur1996's Avatar
Originally Posted by TXsilverado
I also like the idea of having 4 custom tunes on the fly without the need for a laptop.
We have the hand held programmer for our 6012. You can change your tune without a laptop as well. I find it pretty strange as well that they went to rotary analogue switches, on a digital box. Makes no sense. Seems like they backed up with that move. You can get a lot of noise-interference out of a potentiometer. Especially as it gets older.
Old 06-19-2017, 04:15 PM
  #46
Pop N Wood's Avatar
If it is a pot and not a switch. At any rate it is almost certainly being quantized to a digital state so I wouldn't worry about it getting noised up like a TPS sensor. I thought more about it letting water in or getting damaged when someone switches it with a pocket knife or similar.
Yeah they are trying to make everyone happy. Some guys don't like the idea of a laptop. The Daytona system box is similar.
Quick Reply: New MSD ignition controller. Yes, NEW
