vic jr to super vic
vic jr to super vic
here in a week or two,, I'm going to change from the vic jr to the super as soon as I get a couple test runs on changing to e85,, heres a pic of the super , do you think id be better off to run the 4 hole spacer or not.
Spacer Taper
The art of spacers/extension plates is well known.
The "pictured" item shows none of that art.
The correct ones will have a taper "blend" at the exit area for good pressure recovery.
The bottom of a "carbe" has a perpendicular angle is all cases reducing air flow when installed on a "open" bore.
When you blend the exit side of the spacer, the air flow will increase.
There will also be an increase in fuel atomization.
Lance
Lance
Yes, I can put up my cam card
part #54-000-11
sn#c4266-13
its 110plus3
intake .617 ex .589
valve timing int 8btdc 42abdc
ex53btdc 7atdc
107 intake center line
dur .050 231 240
lobe sept 110
part #54-000-11
sn#c4266-13
its 110plus3
intake .617 ex .589
ex53btdc 7atdc
dur .050 231 240
lobe sept 110
I have another set of 243 I need some cnc work,, I have the cut down hollow 2.04 valve but not ex,,, send me some price to do me a set of heads frankenstien,, also I seen on the super the intake is futher over more than vic jr,,, like it could help with flow...
Can't wait to see these results, like I posted in another thread... I've been leaning on swapping out my Vic Jr to a super Vic or the new sniper tunnel ram intake. Not too sure about the tunnel ram they just came out with though, lots of people crying about it.
Originally Posted by http://www.enginebuildermag.com/2008/02/carburetor-tuning-for-performance-and-restorations/
If the carburetor is installed on an open-plenum intake manifold, an aluminum four-hole “screw plate” should be installed under the carburetor to prevent loose throttle body screws from accidentally dropping into the engine. A similar 1/4? insulator gasket will also serve this purpose.
Old School Heavy
I bought a cathedral SuperVic just to run a back to back test on my car, but then the stroker rectangle port engine came together and the test never happened. So, I am very interested to watch your test. What does your converter flash to on the launch? How much do your RPMs drop on the shift?
well I'm just leaving at 2500rpms it will go 4700,,,, ive got the trans break hooked up now,, going to try to leave at 3700 on t/brake.. well I don't know now,,, I don't have a tack in car I have a electric shifter so I took out tack.
I tried no spacer on my vic jr. ,then tried 4 hole, car slowed. I went back to no spacer to verify, ran same et as previous no spacer run. I put a 2 inch open spacer on, the car will out 60ft, out et and out mph on the same day as the runs with no spacer. I leave my 2 inch open on all the time now.
