5.3 Fox on the Cheap - Page 5 - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 01-04-2017, 10:18 AM   #81
6D9
Great build man! Planning something very similar with my new project 72 Vega. Going to be a Craiglist hotrod for sure.
6D9 is offline   Reply With Quote
Old 02-08-2017, 02:30 PM   #82
Thanks! Ive really lost steam... New fuel pressure reg installed last week and turbosmart vacuum rated silicon line to the transmission.
Hoping to drive it this week.
Quote:
CaptSchwag is offline   Reply With Quote
Old 02-12-2017, 10:01 AM   #83
Quick Update. Car now drives under its own power! Carb is really rich still and will need to change the jets. Only issue there is when I had it apart the jets were stuck in the blocks. Going to have to get creative or take them to a machine shop.
Any ideas? The grove were you stick the flat head is starting to chip away.
Old 02-12-2017, 10:54 AM   #84
In-Zane Moderator
ZONES89RS's Avatar
Small set of vice grips.
ZONES89RS is offline   Reply With Quote
Old 02-12-2017, 06:36 PM   #85
This worked! Thank you sir.
Old 02-12-2017, 06:44 PM   #86
Re-jetted this guy, new 30cc pumps and a 5.0 power valve.
It was very rich before! Lol. New plugs into as well but a jacked up a plug wire so I will get a new set tomorrow and will see how this guy wants to run after.
Old 02-12-2017, 08:39 PM   #87
6D9
X2 works like a charm
Old 02-14-2017, 07:16 AM   #88
Quote:
Originally Posted by baronsmith98 View Post
Man you're busting *** on this thing! What ignition box are you going to run? I'd like to see some more reviews of people running the new MSD 6014
following
Jason Higdon is offline   Reply With Quote
Old 02-22-2017, 12:44 PM   #89
So I discovered what an idle eze screw is on a Demon. I believe this was the source of my richness.. 3.5 turns out vs the factory 1.5
Old 02-25-2017, 09:28 PM   #90
what jets did you end up going with, my 5.3 I just built and fired, the plugs look the same as yours. just a film of soot on them. motor idles great, I have a 750 preform carb and started out with 75/76 jets no power valves. (drag car only).
doing a track rental on Mar 3rd, hopefully I can get the plugs to clean up.
79buLS is offline   Reply With Quote
Old 02-26-2017, 07:46 AM   #91
Doug G's Avatar
Jetting has no effect at idle...You'll need to look at you idle air bleeds (IAB), your transfer slot (not open too far), Power Valve size (you're not using), Idle feed restrictors (IFR), and no air/fuel leaks.
An AFR meter will be a great help to see what your changes are doing Vs. constantly looking at plugs
Doug G is offline   Reply With Quote
Old 02-26-2017, 05:30 PM   #92
Doug is correct. Before I went to far I would check your timing and see what you have it set to. Are you running the 6014?
If you are like me, I was using the truck and ho truck timing markers on the box. They are extremely conservative and probably more geared for FI. Not sure why they would put them on this box.
This is my current timing setup.
This is stock Truck...
Old 02-26-2017, 05:33 PM   #93
Also more food for thought. I have no MAP sensor attached and it was reading at 105KPa. If you are not running one like me, I would consider making your timing curve across the board.
I will keep you posted tomorrow. I think I have it nailed now.
Old 02-27-2017, 07:12 AM   #94
Kill Switch Location. Yes I know, will not pass track inspection. It will eventually be put behind the license plate but I was tired of disconnecting the battery.
Old 02-27-2017, 07:14 AM   #95
Cooling system hooked up and filled.Need a catch can for radiator and steam line.
Old 02-27-2017, 07:14 AM   #96
Old 02-27-2017, 07:17 AM   #97
Also, I have a buyer coming to look at the car today. On to the next swap...
Old 03-14-2017, 02:30 PM   #98
So decided to keep the car. I am going to paint here soon and start hunting for interior. i also sold the carb and Im going efi.
Old 03-15-2017, 06:50 PM   #99
Mungface78's Avatar
Glad you're keeping the car. If you don't mind me asking, what made you make the switch to efi?
Mungface78 is offline   Reply With Quote
Old 03-17-2017, 06:51 AM   #100
I have had nothing but carburetors so I wanted to try something new and learn it.
Related Topics
Thread Thread Starter Forum Replies Last Post
Carb 5.3 timing curve? cotyrolin Carbureted LSX Forum 6 09-08-2016 01:58 PM
Carb'd Cammed 5.3 Intake/Carb questions Wisco S10 Carbureted LSX Forum 2 08-24-2016 09:04 AM
Heavy Car cam selection - 5.3 + Carb + TH400 + 650CFM ? APillow Carbureted LSX Forum 4 04-24-2015 01:08 PM
Options for 5.3 w/afm Bowtie972 Conversions & Hybrids 11 12-14-2012 08:19 PM
Turbo Setup Gurus.. I have a few questions.. 1QuickT-A Forced Induction 11 04-01-2007 07:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
