Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Advice on improvements lq4 mustang
Old 09-28-2016, 05:49 PM
88LSxCoupe's Avatar
Originally Posted by camaro98rs
That should work pretty good may pick up some with adjustable shocks but can say how much I dropped from 1.50-1.43 going to adjustable rears and tightening up my front shocks. Also the heavier cars seem to like the stiff sidewall slick or a radial tire.
For what it is it works well! Transfers the weight and no spinning! I'm going to try more timing under the curve as Windmill suggested! I've noticed that my 60' is slightly better as timing increased but I never went over 36*!
Old 09-28-2016, 05:57 PM
88LSxCoupe's Avatar
Thinking back, I just remembered that when it was dynoed it pick up about 30 rwhp going to 38*! I never made a full pull because the technician said that it didn't like the change! He cut it short at about 4.5K!
Old 09-30-2016, 10:40 PM
Bowtiedford's Avatar
def work on your 60' I run mid 130's off of an idle and only run 3:55's and also can hit 200 shot off of the line also and run Pro Bracket radial slick 28x9. 1 to 2 tenths off of your 60' is worth a lot more on the other end.
Quick Reply: Advice on improvements lq4 mustang
