Air cleaner ?
Air cleaner ?
I read the recent results in another thread about the dyno comparison of the different intake manifolds, ported, Edelbrock etc, and somewhat related to this I have a question/dilemma. I am putting together a LSX block 454 with LS3 heads,with a FITECH throttle body system and a super victor manifold and a 14x3 air cleaner. Well I am about 1/4 short on hood clearance, could be a little more. Thats even with a cowl induction hood on my 70 Chevelle. Without that extra clearance it would be way too tall.
Anyways I am trying to figure out the best route and one option is a 2x14 air cleaner, which would give me an inch,or maybe another manifold. The 2" air cleaner has me worried about CFM as its the smallest offered in 14". I thought about a victor JR or maybe the single plane GMPP one. Does anyone know if these manifolds are shorter then the Super Victor? I think the Jr is slightly shorter but what about the GMMP, I can t find any specs. And what do you think about the 2" A.C. do you think I will be hurting myself more going that route then a lesser performance manifold?
Summit lists the height of the top of the aircleaner from the carb. The Moroso units are only 2 1/2 inch above the carb flange
https://www.summitracing.com/search/...2%2B4294949554
Be very careful on the distance of the lid to the vent tubes. Also if you are that tight on room you should not have a choke horn on the main body. Airflow can get pretty wonky as the lid gets closer to the boosters. All about the sharp downward turn into the carb. Usually you are making over a 90* turn. On our dyno we have even gone as far as polishing the inside of the air cleaner. The only other problem I have found is that the aluminum ones can really get hot as they love to obsorb the engine heat. I know on my own car the fuel bowls would get so hot you could not touch them after pulling the air breather off after a pass at the track. The engine was not over 180*. I would set ice cubes on the fuel bowls and take a towel out of the cooler and place it on the intake runners between runs. Finally just ran no breather at the track.
What about the Holley or GM intakes? they are not as tall.
Not sure about power difference on the dyno BUT in real world with shorter intake and taller filter under hood might make more power. Those drop base filters really trap the heat around the carb. A shorter intake with a plastic or wood spacer to keep engine heat from transfering to the carb is the way to go. I have milled 1/2" off an intake and then added a spacer to get the plenum area back but try to stop heat getting into the carb.
Good luck and don't be afraid to think outside the box.
Aleck
Aleck
Be I know on my own car the fuel bowls would get so hot you could not touch them after pulling the air breather off after a pass at the track. The engine was not over 180*. I would set ice cubes on the fuel bowls and take a towel out of the cooler and place it on the intake runners between runs.
Aleck
Aleck
OP. You built a bad azz motor. Don't let an air cleaner hold you back. Get the super Victor. And cut the hood. Either some kind of scoop or a velocity stack. And let that bad boy breathe some nice cool air. Even if you use a 4 or 5 inch filter with the drop base and it only has 2 inches of clearance to the lid. It will still only flow only as much as a 2 inch. You choke down flow and What ever it's choked to is all it will flow. You could do the 2 inch with a K&N lid and get more flow out of it if you don't want to cut the hood. Just a thought. Best of Luck.
