4150 throttle body (come on, it's like a carb) linkage - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 02-27-2017, 06:45 PM   #1
Major Shart's Avatar
Default 4150 throttle body (come on, it's like a carb) linkage
I'm using a FAST 4150 tb with a throttle cable from an '86 Blazer. What are you guys using to link the cable to the carb/tb?
Major Shart is offline   Reply With Quote
Old 02-27-2017, 09:26 PM   #2
On a 4th gen camaro I used this cable end https://www.google.com/aclk?sa=l&ai=...Qwg8IHA&adurl= with factory throttle cable.
tug686spd is offline   Reply With Quote
Old 02-28-2017, 06:06 AM   #3
Lokar stainless braid cable. Looks the best. And works good. You just have to use that plastic peice that the cable goes through on the pedal from the stock setup.
TTur1996 is offline   Reply With Quote
Old 02-28-2017, 08:48 AM   #4
Quote:
Damn it, I already took the factory one out. But either way I would just cut it to fit?
Quote:
Ya I have seen a few of those while searching this. Those do look really nice. I'm going to look into it.
Old 02-28-2017, 11:19 AM   #5
Yes you would just cut the throttle body end ball off and use the universal end. I made my own throttle body bracket because they are all based off carburetor linkage and put the cable to far out off the side for any cable end to mount straight on. Most people pull the bolt out of the cable end like I listed and use a longer one. I felt i didnt want anymore leverage there than I needed. And on the mine the cowl is cut to the windshiel for the most part. I left all the top cowl push pin holes intact and a couple on the outside on bottom so I can still snap the cowl on. Heres a couple pics if you have any more questions just ask.
Old 02-28-2017, 12:40 PM   #6
I have my cowl trimmed back also, and like you I left the holes to reinstall the plastic trim in hopes that all of this fits under my already trimmed (underneath) factory style hood. I have the AED carb bracket already so I think I'll stay with that and deal with the offset.
Old 02-28-2017, 01:33 PM   #7
One other problem I had was the height of where the throttle cable hooked onto the bracket. I knew id be running nitrous one way or another. So in planning for that I put the 3/4" spacer in and that made my throttle cable bracket hit the cowl. So that might be something to look at if you plan on nitrous down the road. Some plates are 1/2" and some are 1", the only one I know of at 3/4" is the stinger. Heres is some more pics of my car, probably should have taken more progress pics but who needs pics when you can just go look at it. 02 Camaro parts pile
Old 02-28-2017, 03:22 PM   #8
That's strange because your cowl is cut farther back than mine and I'm fine even with my Stinger III plate on there. In fact I can even run a 1" spacer with the plate and still be fine.
Old 02-28-2017, 04:38 PM   #9
Doug G's Avatar
Lokar
Doug G is offline   Reply With Quote
Old 02-28-2017, 05:58 PM   #10
Quote:
Might not be to strange. Looks like you have the Jr to my Super.
Old 02-28-2017, 06:18 PM   #11
Ah yes. How much taller is the Super than the Jr?
Old 02-28-2017, 07:27 PM   #12
I have both and never even sat them beside each other let alone measure them. Heres a pic i robbed from an old thread. Super victor under 7,000 rpm
Old 02-28-2017, 08:13 PM   #13
Awesome picture, thanks for posting it. Looks like about an inch at most.
Old 03-09-2017, 04:30 PM   #14
what cfm is that throttle body?
tom70 is offline   Reply With Quote
Old 03-09-2017, 04:44 PM   #15
Quote:
1375 cfm
Old 03-11-2017, 10:42 AM   #16
I have a 1000 cfm and 50 lb injectors on a gm performance rectangular port intake.
Related Topics
Thread Thread Starter Forum Replies Last Post
close up pic of 4150 throttle body with cable??? vbls Generation III External Engine 24 04-22-2016 03:55 PM
FAST 4150 TB with throttle cable bracket WheelsUp84z Parts Classifieds 1 05-12-2015 11:35 AM
Anyone use a 4150 throttle body on a drive by wire car? 1fastxz Generation IV External Engine 0 10-09-2010 07:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
