Anyone tried a carb intake and dist on a ls1? - Page 2 - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 06-01-2008, 05:15 PM   #21
what box is everyone running the Msd box that comes with the Edelbrock kit or the MSD 6010 box, I am going to order the edelbrock victor jr 2908 kit for my LS6 but wasn't sure if I should just order the victor JR intake and get the 6010 box , would I be better off to just buy the edelbrock kit?
Its going into my 67 nova , I am not sure what pan or headers I need yet as well
Thanks
protrax is offline   Reply With Quote
Old 06-01-2008, 05:44 PM   #22
Rodder's Avatar
Thanks
You're better off with the MSD 6010. The Edelbrock can't be programmed with a laptop, and all of the Edelbrock pre-programmed curves have too much total advance.
Rodder is offline   Reply With Quote
Old 06-01-2008, 06:27 PM   #23
Hmm I'll have to get one. Yeah i suppose you could take all of the wires apart I would sooner just cut a bigger hole in my firewall being its a stripped down, homemade minitub, sheetmetal floor pans, dialy driven drag car for me lol.
Shawn MacAnanny is offline   Reply With Quote
Old 06-02-2008, 01:01 AM   #24
Instead of the MSD 6010 you could use the new Fast XIM...
I have not used it but the report from those that have is that it works very well.
http://www.compperformancegroupstore...y_Code=XFI_IGN
Sledgehammer is offline   Reply With Quote
Old 06-02-2008, 05:02 AM   #25
great post
Old 06-02-2008, 09:35 AM   #26
70LS1Nova's Avatar
So, what software is used to "tune" the msd box? Does software come with the 6010 kit? Or do we something like lsedit or hptuners?
70LS1Nova is offline   Reply With Quote
Old 06-02-2008, 10:05 AM   #27
SMAX's Avatar
The box comes with a cd that you just put on your laptop.
SMAX is offline   Reply With Quote
Old 06-02-2008, 10:12 AM   #28
Pop N Wood's Avatar
Good to know there is an option. But for $50 more and NO HARNESS it will be an expensive option. Guess they expect the user to strip down a factory FI harness?
Pop N Wood is offline   Reply With Quote
Old 06-02-2008, 10:48 AM   #29
the msd 6010 comes with a full harness and is truly plug n play
regards
chris-m is offline   Reply With Quote
Old 06-02-2008, 05:58 PM   #30
Yeah MSD 6010 came with CD and cable for less. Also i dont really see how it could be easier to tune with. I guess maybe for FI but for a standard setup it just does not get any easier. Just dragging dots up a line graph to the correct timing you want at the specified rpm, then a separate table for the ammount of timing increase you want at a specific ammount of vacuum. It also uncludes a 2 step rev limite (add 12v to wire to activate) and a timing retard (add 12v to wire to activate). I really dont see how it could be made much better lol.
Old 06-03-2008, 12:05 AM   #31
DCx
what he said....
here is a pic of the software and my graph. i use a serial to usb connector and i also updated my software from MSDs website. the cd with the box is outdated. just plot a graph, key the ignition to give it life, save the file to the MSD box, and start the car.
tune carb accordingly and enjoy. i dont run any vacuum advance on mine.
DCx is offline   Reply With Quote
Old 06-03-2008, 04:32 AM   #32
i have vac advance adding about 8-10 deg at idle/light throttle to clean it all up for exhaust smell etc but otherwise my advance curve is almost identical to that one above. after 3000rpm and at full throttle i have no added timing just 29deg maximum to the redline. my ls1 made something like 400rwhp with a demon 750cfm carb and this setup plus a mild cam and drives perfectly.
Old 06-03-2008, 06:18 AM   #33
forcd ind's Avatar
while i was playing around with my timing, i downloaded it to the msd box with the motor running, you could hear the engine actually change as it accepted the new tune, kind of amazed me, being computer stupid
do you have a pic of your map graph, if using it-still confused about it, but getting there, since im turning up the boost
forcd ind is offline   Reply With Quote
Old 06-03-2008, 07:48 AM   #34
Sheephead's Avatar
Has anyone run a large cam,(like a ms3) with the carb and msd set-up?I,ve heard efi designed cams don,t work as well with carbs and i should have a cam designed for carb.
Sheephead is offline   Reply With Quote
Old 06-03-2008, 09:29 AM   #35
rojs234's Avatar
I agree with DCx , it is definately a good idea to go to MSD's website and download the newest software. Works lots better. My graph is similar to his without the drop back at higher RPM. I may have to try that. I still can't get my head wrapped around the way the vacuum is displayed. I'm used to the old style vacuum guages, but I will figure it out eventually. I really like the feature where you can maximize the little 3 guage panel to the full screen size. Us old guys have trouble reading them at the regular size,. Ha! As far as the cams to use, most FI cams have wide lobe centers to help with emissions and smooth out the idle so as not to confuse the computer. A lot of guys with carbs like the narrower lobe centers (say, 108-110) , because it usually helps the low and midrange torque. The MSD box is the way to go in my opinion.
rojs234 is offline   Reply With Quote
Old 06-03-2008, 12:29 PM   #36
Rodder's Avatar
Quote:
It works the same way as vacuum gauge, only the numbers are different.
Take the a standard vacuum gauge like this: http://www.jegs.com/webapp/wcs/store...-1&showValue=1
Now where it has "30", cross that out and write 0 KPa. And where it has "15", cross that out and write "50 KPa". And where it has "30", cross that out and write "100 KPa". Cross out 5/10/20/25 cuz I don't feel like converting them . Does this make it easier to visualize?
Old 06-03-2008, 05:03 PM   #37
DCx
im running a MS3 cam on a 113lsa. the car starts and runs fine with this cam. im waiting on getting a FAST dual wide band meter so i can tune my demon better. i have a rich tail pipe at idle.
im yet to feel the full potential of my car because 3rd gear is trashed in my t56. so just driving around i can only rip 1st and 2nd.
Old 06-03-2008, 05:39 PM   #38
i got the specific cam grind (crane i think) that was done for edelbrock for their carb conversion on the ls1. its supposedly 220/220 and 111lsa so quite mild without massive lift. they also list a stronger cam around 230 deg if i remember. mine seems to work well tho, i did use the GM carb inlet manifold tho after being messed about waiting for edelbrock stock.
Old 06-03-2008, 09:00 PM   #39
Sheephead's Avatar
Thats good to hear.Which intake and size demon you running?The demon they sized for me was a 750 double pump and i,ll run Victor JR.
I have efi now,but don,t want to deal with wiring harness .Plus what i ,ve read about this msd 6010 which will work good with the trans brake on 1st rev limmit and the retard for nitrous.I like that it comes with it,s own software and i won,t have to buy hptuners.
When you get your car tuned let me know how it runs and maybe dyno #
Old 06-03-2008, 09:48 PM   #40
Quote:
I'm running a custom ground 236/236 .651/.651 110+4LSA runs great.
Related Topics
Thread Thread Starter Forum Replies Last Post
going to carb my lq4 69 nova Carbureted LSX Forum 6 10-21-2015 01:51 PM
help me tune my metering block homemade87 Carbureted LSX Forum 20 04-11-2015 07:16 AM
Budget Carbed LS swap info ZONES89RS Carbureted LSX Forum 0 01-12-2011 07:55 PM
brand new cammed ls3 1994t/a Conversions & Hybrids 12 06-05-2010 08:28 PM
Tags
04, 53, box, carb, carburetor, combo, convert, cruise, edelbrock, intake, jr, ls1, ls1tech, timing, victor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
