Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
94 lt1 question
Old 11-03-2008, 02:15 PM
LTnasty's Avatar
Default 94 lt1 question
Would it be ok if i removed my smog pump all together? I want to get rid of it so i can do some water pump and possibly ignition work.
Old 11-03-2008, 10:06 PM
SoxXpupPeT's Avatar
yeah you can remove it. make sure you plug up the holes in your manifolds tho. youll have the SES light on tho which is annoying but its all good. cleans up the engine bay quite nicely
Old 11-04-2008, 05:53 PM
multmigs's Avatar
ITs a 94 you won't have any CES light on and do yourself a favor and go buy the correct plugs at NAPA or somewhere, they are oil drain plugs for a 95 dodge 2500 diesel P/U and they not only clean it up but seal off any possible exhaust leaks....
Old 11-10-2008, 04:06 PM
qwickLT1WS6's Avatar
remove it, there will be no lights, just make sure your remove all the parts that are connected to it
Old 11-10-2008, 06:19 PM
Indyjc's Avatar
I have a 94 lt1 also, will removing the smog do anything other than clean up the engine compartment? Thanks
Old 11-16-2008, 03:31 PM
gnasty1521's Avatar
Possibly fail emmisions, but all the impala guys do it for cheaper headers... Then again, all it does is help the cats get hot...
Quick Reply: 94 lt1 question
