Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Car stumbles
Old 02-27-2009, 03:27 PM
Red97LT1's Avatar
Default Car stumbles
When my car gets up to operating temperature,it want's to stutter as if it was misfiring.It does it when it's cold also,but is worse after the car warms up.Some times it gets to the point I think the car is going to stop.After I get up to 45+mph it stops.I'm not showing a check engine light and my scanner isn't showing any codes.The opti,plugs and wires were replaced a year or so ago.Any ideas as to where to start looking? Thanks
Old 02-27-2009, 03:54 PM
blk/slvr02ss's Avatar
Sound's like the opti spark again.
Old 02-27-2009, 04:00 PM
Red97LT1's Avatar
Great. Anyway to check it,before I have it replaced?
Old 03-11-2009, 07:36 PM
Red97LT1's Avatar
Just wanted to give an update.Been out of town til today and started the car.It wanted to stumble ,usually didn't do it when it's cold.Going up a hill really makes it want to stumble.Checked the injectors again and the two rear ones on the drivers side don't seem to click or pulse and strong as the others.Could it be that easy?
Old 03-18-2009, 06:39 PM
Red97LT1's Avatar
Injectors on the drivers rear side don't seem to be pulsing/clicking as loud/hard as the others.Could it be that simple?
Old 04-02-2009, 04:54 PM
maxgee's Avatar
I doubt injectors is your issue. If you have headers, take a straw when the car is running and drip some water on the headers to see if the suspected cylinders sizzle the water. Or if you access to a laser thermometer...you can measure the heat out of each to see if they are heating up in the same range.
Check all your basics, but I'm betting it's your opti.
Quick Reply: Car stumbles
