Some questions about my CAMARO SS
Hi everyone
I had some queries and I want to clarify them,BTW I have 2001 LS1 CAMARO SS so:
1-How can I be sure that my CAMARO is an SS?? w/o considering engine,hood,rear spoiler and rims
2-Which intake is better,the new Weiand Street Warior LS Series or F.A.S.T 92mm intake??
3-What is the standard size's for Injectors,spark plug wires and Throttle body for standard CAMARO SS??
4-Im having Hoosier semi-slicks on rear wheels and my gear,clutch,shaft and differential are standard (not racing),so does it effect them??
5-Can I install Magnuson Supercharger (MP112) on my CAMARO?? cauz as the info from their site it only comes in c5 corvette and GTO?!!
Thank u
1. Look in the drivers door for the sticker with RPO codes. If there is a WU8 then it's a real SS. If it has Y2Y also you have additional SLP options. Check your passengers door for those.
2. No idea
3. 28lb injectors, 75mm throttle body, dunno about the wires
4. It should not affect them
5. I have no idea
2. No idea
5. I have no idea
thank u very much 4 the INFO,it help me a lot
But still I didnt understand 1 thing,why the chasis number on 1st sticker(Service Parts Identification) its not the same as the second sticker(MFD BY GM OF CANADA) AND THRID STICKER(Tire Pressure's) which are in bottom of it?? As I goin throw PICS of different SS camaro's I seen the the numbers are same in all 3 stickers!!
Location: Your girl's back door giving her the long stroke while you're at work
The WS6, Firehawk and SS came with 275/40/17s
If the car is a 6 speed then the rear end could be on borrowed time. Just depends on how hard you launch the car.
See the link below on how to get the build number for the SS cars. He'll be able to tell you if it is a true SS
https://ls1tech.com/forums/5955403-post1.html
Hi everyone
Thank u
2. THe FAST 92mm would be better but without a cam and some longtubes at least it is way over kill. You really needs heads to take full advantage of the FAST. I make about 430ish at the wheels through a LS6 just fine..
3. THE SS got the same as every other LS1 of the year.
4. Slicks on a stock rear and 6spd is asking for trouble. People break there rears on street tires.
5. THe kit has to be for the LS1 in the F-body to be sure everything fits. I would call them directly..
Z28/2002 ,, waldershrek ,, SOM02WS6
Thanx guys for ur assistance,it helped a lot, I really greatful and thankful to goin this fourm,each day im learing something new
May ALLAH bless u
May ALLAH bless u
The Magnacharger will NOT fit under the hood without lowering the K member and cutting into the cowl to make room for the drive.
I am however working with a new company that manufacturers a 3L twin screw top mount supercharger that may fit under the hood of an Fbody with little to no modification. PM me if your interested.
**Sorry, Not a sponsor here YET**
Moderator
1. WU8 rpo code on driver side door. Passenger door may have SLP sticker (may not)
2. FAST 92
3. Injectors depend on year 01 were 28.8lb, TB is 78mm
4. No effect.
5. There are Magnacharger kits for F-bodies. They are modified from other kit's. check the sponsors forums for them. I believe they require you to lower the K-member.
2. FAST 92
4. No effect.
Marhaba, Camaro ss 2001, Keyfuk?
that sounds great bro but I prefer magna then SC cauz of its MP112 the same SVT COBRA tune u got my point?
I think and tell u OK,I hope u become sponsor soon, THANX
2. FAST 92
4. No effect.
2. FAST 92
4. No effect.
2.I c
3.OK what about 97-98 years?
4.Actually it effected and now my car has problem Idont where excatly cauz its making sound uder the gear area (maybe shaft or gears)
5. Aha but what u ment by (K-MEMBER) ??
Take last 8 digits of VIN code and call SLP (1-732-349-2109) and ask them what build # your SS is. If it's a true SS, they'll tell you what it is. If it's not a true SS, then they won't have a listing for your car. The K-Member is the undercarriage of the car that the rack & pinion mounts to and the motor mounts hold the engine in place.
Its hard from me to call from my countray cauz im very far away,I send SMS to SLP SPONSOR mr.HABERGER but he didnt replay till now
AHA so its kind of risky to put MAGNACAHRGER in CAMARO
Thanx 4 the INFO VERY MUCH
Moderator
1. I believe the orignal RPO sticker is not sticked 2 my side door cauz the chasis numer is different
2.I c
2.I c
5. Magnacharger will not fit under the cowl/windshield w/o modification to the cowl and/or using shims to lower the K-member.
