ls6 motor into 02 Camaro?
Moderator
Nothing. It's the same. Block is different in the way the rear coolant passages go. Heads are 243 casting (better flowing). Cam is a little bigger (not much). Has an LS6 intake.
Vette accessories are different. You will need f-body accessory's & crank pully. Other than that, they are the same engine. In fact 80% of 02 f-bodies came with the LS6 block & ~20% of the 01 cars did too.
THe ls6 is not 6.0 it is 5.7. Its not worth the effort to pull the whole engine for a 40hp gain. You can just swap the heads and cam into your motor and not have to pull everything off..
Moderator
It's really not worth it, if you don't need to. If you have a blown engine and are doing the swap that's one thing.
You need to check the casting # on the back of the block below the heads to see if it's an ls6 block. I don't have the #'s in front of me, you will have to do a search to find them.
LS1TECH & Trucks Sponsor
It's not dry sump. You're also going to need a lingenfelter converter to convert the 58x signal to 24x for your computer to run the engine
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
