passenger door catching fender?
i have a stock 99 z28 m6 and just reccently the passenger door is catching the fender. is it too far gone or is it possible to re align it and weld some sub frame connectors on it?
Check 2 things:
1) The fender mounting tab below under the car. Make sure it didn't get bent out of whack. Common thing that happens when people jack up the car without paying attention.
2) Open the door and look in the space where the hinges are. Near the top is a bolt that holds the middle portion of the fender. You can loosen it and adjust the fender that way as well.
