Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
02 camaro N/A 12's?
Old 08-21-2009, 02:24 AM
ls2supersport's Avatar
Default 02 camaro N/A 12's?
WHat all has to be done to an ls1 or ls2 camaro to get it in the 12's? Naturally aspirated of course. Can it be done with just bolt on's?
Old 08-21-2009, 07:09 AM
Avaric3's Avatar
search THAN ask questions. and dont tell us you have already
Old 08-21-2009, 11:57 AM
LT1Formula007's Avatar
Air Lid, Intake Manifold, gears, stall, full exhaust, drag radials, Nitrous, Wieght reduction, etc....
Lots of stuff will get you into the 12's. If you want high 12's it won't take much. If your looking for low 12's you'll be adding a few more Items.
My stock 98 Z with ONLY pacestter Longtube headers and TSP 3" True Duals and bald nitto drag radials went 12.99 at 109 mph. That was with a 2.xx 60' time and a 2.73 gear in the rearend.
Good Luck
James
Old 08-21-2009, 04:13 PM
Moderator
davered00ss's Avatar
Do a search, there are plenty of bone stock down to the air filter & tires that have ran 12.8's.
There are even bolt on cars in the 11's, with weight reduction & suspention set up right.
Old 08-21-2009, 07:51 PM
^^^ TRUE STORY!
Try searching and you'll see. Also look in the 12 second and 11 second club section and there is usually good threads in there that will lead you in the right direction...
James
Old 08-21-2009, 11:40 PM
thanks guys and im searching for now on
Old 09-04-2009, 11:25 PM
No problem, good luck!
James
