Questions on 2000 Convert Z28 with LS1 eng
I'm looking at all stock 2000 Z-28 Camaro Convertible with the LS1 engine, it has 40,000 miles is a automatic and loaded car.
Question - what should I be concerned with upon inspections?
What is a car like this worth? it's is clean car inside & out private seller
Any issues with the yr 2000 Camaro's, convertibles or LS1 engines, auto trans etc???
Your input would be appreciated Thanks Much!
Check the normal things that you would check.. Transmission slipping/rearend/oil leak/etc etc etc.. Not really anything "wrong" with these cars. Check window motors/crack in door panels and things like that, good negotiating things.
I have a 99 vert v6 and obviously you should make sure the top is in good working order and on the inside check the top for wear on the sides. take it for a test drive and good luck. on these cars almost anything can be replaced. check the weather stripping as well.
