Help: Odometer red LEDs stopped working... 98 Camaro LS1 A4...
Well, not that it is a major problem but it looks like the LED lights that light up the digital display completely stopped working, yet the rest of the cluster functions just fine, from the night time cluster lights, coolant temp gauge, oil pressure gauges, speedo, tach, SES light, etc. Is this something as simple as a blown fuse in the cluster or does this whole cluster have to be replace if I want to have this feature back? At least I have a Scanguage II which can serve as my trip odometer... Any help would be appreciated... Thanks!
Tilt steering, remove the plastic cluster bezel piece exposing the tach and speedo assy (2 screws), remove the cluster, wiggle it and it eventually pops out. Disassemble it from the back and replace bulb, reassemble, pop cluster back in and pretty much you're done. It can be rather difficult the first time. Be careful with the plastic trims. Hope this helps...
