swapped colums, now car wont start - LS1TECH
Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Thread Tools Search this Thread
Old 01-06-2012, 02:59 PM   #1
97_C5's Avatar
Default swapped colums, now car wont start
Ok so got a buddies 97 m6 car, with vats bypass. With that said we recently swapped the colum out and put a column out of a 94 auto car, now the car cranks even with the clutch pedal not depressed, and fuel pump is not kicking on...any ideas what the problem is?
97_C5 is offline   Reply With Quote
Old 01-07-2012, 07:13 PM   #2
Wrong ignition. Auto and manual are different.
black01 is offline   Reply With Quote
Old 01-09-2012, 02:50 PM   #3
Quote:
Ding ding. Gotta fix that first.
maxharvard is offline   Reply With Quote
Old 01-11-2012, 11:50 PM   #4
97_C5's Avatar
Quote:
It was a auto, and swapped ignitions, nothing still. So got a new one still noting. Now I questioning the wiring on the column. Cause 93-95 the anti theft and bcm were separate units, 96-97 bcm controls the anti theft
Old 01-12-2012, 03:28 AM   #5
97_C5's Avatar
just as a update the car cranks, and that's about it. I tried the the fuel pump jumper wire that comes out by the ecm under the hood pump did not prime just clicked. Also talk with the owner and the security bypass on the bcm has been bypassed. Checked wiring there and has power while cranking. Also the f/p relay has power. Anyone have any ideas or direction I should take as next steps for trouble shooting.
Tags
97, bypass, camaro, ls, lt, rebuild, security, ss, start, swap, vats, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
