I have some Hella Fogs that I have installed in my car and would like to know if I ca
I have some Hella Fogs that I have installed in my car and would like to know if I can use this switch with a relay. The switch has 6 blades on it so how do I determine which blades to use. I want to use this switch since it matches my interior switches whereas the 3 prong switch that came with the Hella Fogs doesnt match at all. I may have a relay that came with the Hella Fogs, I am not sure. The Hella fogs have 3 wires coming from it.
Thanks
http://i559.photobuc...inoutlights.jpg
Thanks
Use a meter on the switch to find continuity between the blades when the switch is in the on position and you should be fine, be sure to use a relay in the circuit so you do not burn up your switch.
