driveshaft specs - LS1TECH
Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
driveshaft specs
Thread Tools Search this Thread
Old 03-21-2012, 02:43 PM   #1
Unhappy driveshaft specs
i have a 2002 camaro z28 m6 and i recently twiseted and snapped my drive shaft and i need help. does anyone know the dimensions of this drive shaft so i can go to my local drive line specialist and get one made for me. i need specific dimension on getting one made so if anyon could help thanks a lot
beastlyredz28 is offline   Reply With Quote
Old 03-21-2012, 03:04 PM   #2
mikh338's Avatar
Quote:
stock will be 44 1\4" for a 10 bolt\12bolt. are you having them build you one thats the same as stock? if you are, i would highly upgrade to a PST or something like that those stock DS are absolute junk they are so thin and weak dont waste your money on another one. heres a link for you
http://shop.brutespeed.com/Driveshafts_c1090.htm
mikh338 is offline   Reply With Quote
Old 03-21-2012, 03:18 PM   #3
thanks a lot man that helped me a lot. hes not making me a stock one hes using a higher grade aluminum and different yoke.
Old 03-21-2012, 03:21 PM   #4
mikh338's Avatar
ok great. how much is he charging if you dont mind me asking? the aftermarket aluminum ones on these sites get pretty pricy!!
Old 04-10-2012, 10:51 AM   #5
he was gonna charge me $290 for it but i went with pst steel one instead.
Related Topics
Thread Thread Starter Forum Replies Last Post
Vortech supercharger bottom mounting bracket dimensions for 50$! sofixy89 LT1-LT4 Modifications 4 03-28-2014 01:47 PM
Blueprints / dimensions for LS bellhousing? Nashty Conversions & Hybrids 2 09-07-2012 01:06 PM
Hood dimensions for 02 WS6! JamRWS6 General LSX Automobile Discussion 1 05-03-2012 03:55 AM
T56 dimension Jesus Freak Manual Transmission 7 01-10-2012 04:03 PM
Those who made their own alternator relocation brackets step inside boost21 Forced Induction 17 04-02-2011 01:01 AM
Tags
02, 10, bolt, camaro, drive, driveshaft, fbody, install, ls1tech, pst, shaft, specifications, specs, stock, upgrading, weak, ws6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
