Wiring harness help
Wiring harness help
I am putting an LS3 into a 1991 Camaro, and the engine comes with the GM harness. I need a wiring diagram for the wires that come out of the steering column, colors and function. Can someone please direct me to this information.
thirdgen.org
there is a forum specifically for swapping lsx engines into thirdgen fbodies. make sure and read all the stickies. pocket is the wiring guru when it comes to that stuff.
also, a haynes or chilton manual would give you the info you need.
i had pocket merge my harness with the lsx harness so it was all plug and play.
