'04-06 GTO in a '67 Camaro?
Has anyone here tried swapping a 2004-2006 complete drive train into a 1st gen F-body? I'm just gathering info here, but I'd be curious to find a build thread or at least some more info on this. I did a little searching but couldn't find what I was looking for.
I'd be looking at an LS1 or LS2 with a 6 speed. How does the shifter line up with the existing tunnel hole? Motor mounts, accessories, oil pan etc. Any help is appreciated.
You need to goto http://www.pro-touring.com and you will find everything you need.
-The GTO A/C will require a frame notch the frame or get different brackets
http://www.kwikperf.com/ cheapest place
-You will have to swap the oil pan
-The tunnel will need cutting and change the GTO shifter to a Camaro shifter and it will sit in a good location
-Get some motor mount relocation plates
I ran 12.50 1.9 60 with a bone stock 06 GTO engine.
