95 camaro suspension problems
I replaced my coil springs, coil spring insulators, struts, strut mounts, strut bearing plate insulator, ball joints upper and lower on both sides, tie rod ends, and control arm bushings and still at higher speeds like 60-70 mph the steering wheel shakes a little and wants to turn to the right if i was to let go plz help
is it prob just the tires? my back passenger side is showing belts because of when i had the bad suspension and i moved it to the back the bad suspension wore a lot of my tires
