3.4L to Lq9 swap which ecu/pcm
you can make anything work, just depends on how much time/effort you want to spend.
as far as the ecu, you need to decide if you are going drive-by-wire or drive-by-cable for your throttle body. if you can get a harness from a 99-02 camaro, that would be ideal for drive-by-cable
