Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
68 Camaro LS1 6spd
Old 11-29-2012, 09:50 AM
DocHall's Avatar
Default 68 Camaro LS1 6spd
Comments &/or questions:
My 68:
http://jmichael.info/68SSmain.htmhttp://jmichael.info/68SSmain.htm
Last edited by DocHall; 11-29-2012 at 09:51 AM. Reason: learning how to insert link
Old 11-29-2012, 10:39 AM
creiss21's Avatar
SSSSSSWEET!!!!!
Old 11-29-2012, 10:41 AM
DocHall's Avatar
Thanks.
DocHall
Old 11-29-2012, 06:36 PM
Camaroking1996's Avatar
Dam that thing is clean!! Specs on motor? And what seats are those?
Old 12-11-2012, 11:33 AM
Aston Tibs's Avatar
Questions:
Are you using the stock sub or aftermarket?
Is that a 1st gen radiator? What fans did you use?
How did you run your fuel system?
Did you relocate your battery to the trunk to run the CAI?
What did you do to make the stock console work?
If you couldn't guess, I am just starting the same swap on my 68 Camaro. I am thinking about using the original fans off the 99 TA the engine came from but I would have to fab custom brackets to make it work.
Old 12-11-2012, 11:41 AM
maxharvard's Avatar
I have a question and a comment...
is this car as badass as it seems?
Comment: Yes!
Old 12-11-2012, 04:47 PM
Gravik's Avatar
Awesome.
If only F body's had that much engine bay room.
Quick Reply: 68 Camaro LS1 6spd
