Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Which 1st gen Camaro headers?
Old 12-10-2012, 06:25 PM
67rally's Avatar
Default Which 1st gen Camaro headers?
I'm wondering what you guys are running for headers on your 1st gen Camaro LS swaps?
Budget is a concern, but more importantly I want something that will fit well with the PS box, ceramic coated and preferably long tube.
Can you post brand, part #, and price paid? Also, if you have pics, that would be great. Thanks.
Old 12-10-2012, 07:12 PM
Doug G's Avatar
Don't have the numbers off hand and I have a manual box...but the Dynatech headers fit the bill for me (not running yet ) eveything cleared good...except 2 plug wires. These are the 1 7/8"
Edit: header P/N 715-11510
http://www.dynatechheaders.com/m_camaro_67_69.html
Old 12-11-2012, 11:10 AM
maxharvard's Avatar
I'm running the Stainless Works headers made for the SpeedTech frame.
Old 12-11-2012, 05:39 PM
67rally's Avatar
Looks good Doug. Which plugs did you have a problem with?
Maxharvard, what's different about those headers vs a set for a stock subframe? Any pics?
Old 12-12-2012, 10:33 AM
maxharvard's Avatar
The speedtech versions are slightly different for the STP subframe.
However, they do make a version for the stock subframe.
http://www.speedtechperformance.com/...cat/cat253.htm
Old 12-12-2012, 05:52 PM
Doug G's Avatar
#5 and #7.... both will need 90* boots
Old 12-14-2012, 09:48 PM
LS1 pwrd NOVA's Avatar
Hey Doug what plates you using? Are you at 1" setback or less? What oil pan?
Old 12-22-2012, 02:20 PM
69Lsx6.0's Avatar
Hi Brent, I used Hooker Long Tube Headers. They fit perfect. They clear the power steering box without any issues.
Old 12-22-2012, 07:23 PM
Doug G's Avatar
Yes 1" set~back and a Holley pan (level with bottom of crossmember)
Old 12-22-2012, 07:27 PM
67rally's Avatar
Thanks. Two quick questions.
1) What steering box are you using? (I have a Delphi 670)
2) Is this the part # you used: Hooker Headers 2288-1?
I just missed out on two nice low mileage LS engines. One I got outbid last second on eBay, and one was still listed on LKQ but had already sold. The search continues...
Old 12-22-2012, 07:28 PM
67rally's Avatar
Cool. That's the pan I'm looking at.
Out of curiosity, why the 1" setback?
Old 12-23-2012, 10:25 AM
gheatly69's Avatar
I used Doug's LS swap headers with their mount plates. They fit perfectly and there is no issue with spark plug clearance - I used the stock plug wires.
I was able to dimple the #3 tube and use the factory manual clutch linkage. I also have a late model quick ratio steering box.
Old 12-23-2012, 08:28 PM
Doug G's Avatar
Motor set-back to match stock tranny location.
Old 12-24-2012, 06:54 AM
Doug do you have room to move your engine forward with those headers?
If you look at drivers side only, how much room is there from the tubes hitting the steering box? Especially the tubes behind the box. Or even the #1 tube hitting the mounts or something else as the way it's routed in this pic you took. Could you look n let us/me know? I want to move my engine from 1" setback to 1/2" setback or 0" setback.
Old 12-24-2012, 08:38 AM
67rally's Avatar
Last question...
What are you using for a tranny? I have an old Saginaw, so I'll be upgrading to a T56 or a TKO of some sort. I don't think the Sag is going to last long behind an LS engine.
I didn't see any info posted in your thread on TC.
Old 12-24-2012, 09:07 AM
Everett#2390's Avatar
Looks nice so far, Doug....Everett
Quick Reply: Which 1st gen Camaro headers?
