need some intell 01 camaro hurst install
i just bought a 01 z28 and ordered a hurst short stick and ****(just stick and **** already has factory hurst shifter) what i want to know before i dig into it do i have to pull the console for this and/ or does the boot remove with out pulling it thanks any help would be great
Its very easy to install, you can remove the upper console if you want, but i got away with just removing the boot. Remove the shift **** first, remove the boot, then remove the (2) 13mm bolts holding on the original stick. Bolt the new hurst short stick and replace what else you took apart and boom, you'll wonder why you didn't change it sooner lol.
It's not mine! woo hoo!
I'd suggest just pulling the console out. You may be surprised at all the funk you find hidden in there...
One 10mm bolt on each side under the center stack, 10mm under the ash tray, and I believe three 10mm in the console itself. The rubber surround covering the shifter is 7mm.
