built 4L60E output shaft extremely hard to turn clockwise
After assembling the gear train and installing the pump, I checked endplay and have none on the output shaft. The input shaft turns fine, but the output only turns counter-clockwise easily (looking at end of transmission, and output shaft). I can turn it if I use two hands and a towel, without bind, but it is extremely tight and difficult to turn. Is this acceptable? I do not have servo or tail housing installed. Thanks.
