Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
69 suspension upgrades to handle LS3
Old 04-11-2013, 12:16 AM
69LS3's Avatar
Default 69 suspension upgrades to handle LS3
Currently everything is stock including mono leafs, bushings, springs, steering arms.. basically everything is stock. I would like to know what would be the best reasonably priced suspension system to handle a 6L80E and LS3. Keep in mind this is a daily driver and don't need a track set up.
Old 04-11-2013, 08:20 AM
maxharvard's Avatar
A stock setup for suspension will be just fine if you don't care about performance.
The only issue is going to be weight, but since a standard LS3 weighs less than a typical small block 350 with a carb, you'll be just fine.
Old 04-20-2013, 01:48 AM
6D9 Matt's Avatar
Look into some Hotchkis packages.
Quick Reply: 69 suspension upgrades to handle LS3
