power steering cooler issues
has anyone found oil in there radiator and also have to keep adding oil to power steering pump? i think that mabye fluid is being transfered in inside the power steering cooler. is the power steering a higher pressure than that of the radiator? i tried running car with just radiator hooked up and not the power steering and no anti freeze came out so i didnt think there was a hole. but i keep adding fluid to power steering and its not leaking anywhere. i have a 02 z28.
It's not mine! woo hoo!
Here's a very comprehensive thread about the issue:
https://ls1tech.com/forums/general-m...g-success.html
Personally, I added the aftermarket cooler after removing the factory one. If I were to do it over again, I would just delete the factory one and only add the aftermarket cooler if it were necessary.
