2002 3.8 starting problems
I have a 2002 Camaro 3.8 with 125k milkes on it. I just drove it for about 5 mins, parked for about an hour, tried to start it and couldn't. I got it running for about 30 seconds but was running bad almost like if you left the choke on. I tried to rev it but it would shut off once the rps went back down. I have never had this problem or any other problems with the car. Please help with any suggestions thank you
My son just had this happen to him not long ago all I can tell you is have a friend turn the key to the on position while you put you ear to the gas filler tube if you don't hear a whine or buzz of some sort it may be the fuel pump if it is the fuel pump it is a pretty simple job if you have any mechanical skills at all there is no way to change it other than drop the tank though unless you want to cut a hole in your trunk pan and I wouldn't do that if it isn't the fuel pump it could be a number of things so start with it first and work from there
