Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Ls6 vs Fast Intake
Old 07-27-2013, 10:02 PM
Z28U!'s Avatar
Default Ls6 vs Fast Intake
Which one to get? Is the extra $300-$400 worth it with the Fast? Anyone have comparisons on the?
Old 07-28-2013, 03:20 PM
Bad28's Avatar
It really depends on what your overall goal is with the car and where you have money tied up @
Old 07-28-2013, 05:16 PM
BrntWS6's Avatar
You also should get everything forward of the TB to take full advantage of it if. FTP lid, bellows, MAF....and you'll need a tune. **** adds up.
Old 07-30-2013, 11:09 AM
Z28U!'s Avatar
Well I have the slp lid, ssra, below, fra up front so far and just ordered the potz tb
Old 07-30-2013, 11:19 AM
It's not mine! woo hoo!
demonspeed's Avatar
I'd stick with the LS6 for now considering you just ordered a stock ported TB and have all the other stuff that is optimal for the LS6 (and will need upgraded for the FAST). You might want to consider doing the LS6 pcv conversion while you've got it off.
And like was mentioned, the swap will really add up as it's not just buying the manifold. You'd be better served getting the LS6, LT's, and tune -- and still likely have less money in your little mod spree.
Old 07-30-2013, 12:37 PM
BrntWS6's Avatar
What I mean is a 4" bellows, FTP 98mm lid, GM 90mm MAF. Not sure what other mods you have but all this stuff will compliment the FAST intake to get the most out of it.
I gained 20rwhp with a FAST and that setup but I already had H/C/E. If you only have bolt-ons so far I personally wouldn't bother with a FAST unless you plan on H/C later.
Old 07-31-2013, 06:53 PM
etrain783's Avatar
Same as everyone else save the fast for a cam build. With minimal mods you wouldn't notice much. You can get an ls6 cheap, LTs free exhaust and tune you'll get some good gains
Quick Reply: Ls6 vs Fast Intake
